1 - 3 of 3 Posts
Hey guys new to the group. I have a 05 300c and it won'tgo over 40mph. I changed the conductor plate speed sensor valve body repair kit , And filter still the same thing. Could it be a bad trans or the pcm? Any help would be greatly appreciated.
Welcome to the forum. Tell us more about the vehicle....mileage, mods., any other recent work done to it and, if so, who did it? . Are there any codes showing? Does it shift through all the gears? Any slipping/RPM flaring on shifts, slow and/or harsh transition between reverse and drive or vise versa, etc.? What kind of stuff was in the bottom of the pan when you first took it off.....type of debris (metal/aluminum shavings, etc.) and was there anything on the magnet? What type of fluid did you put in it and how much? How did you verify the fluid level is actually correct?
1 - 3 of 3 Posts
