1 - 1 of 1 Posts
Have A 07 Limited That Was Loaded Except It Has Apparently A Base 6 Speaker System. I Have A Complete Boston Acoustics Set With The Sub, 6 Speakers And 322 Watt Amp That I Removed From My Daytona When I Did A Complete Kicker Swap Out. I Installed The 8" Ba Sub In The Factory Location In The Rear Shelf, The Plug And Harness Was There And It Was Plug And Play. Then I Went To Swap Out & Install The 322 Watt Amp In The Original Location Under The Steering Wheelthinking There Was A 276 Base Amp But There Is No Amp To Unplug So I Looked Every Where For The 2 Plugs For The 322 Watt Amp And I Could Not Find Any. Does Anyone Know If There Are Plugs And I Over Looked Them Or Are They Part Of A Body Harness If You Have The Ba Group 11 Option To Begin With Or Is There A Seperate Harness From The Radio (6 Disc) To The Amp.any Help Is Greatly Appreciated, Thanks, John
1 - 1 of 1 Posts
