1 - 20 of 21 Posts
Discussion Starter #2
Just as a note, seems like the accelerator will stick (depress it and it will hold at roughly 5-6k for a while before dropping)
All the pulleys feel tight and it makes the same sound without the serp belt on
Kinda hard to troubleshoot a rattle over IM but without a belt (which my first guess would have been water pump) I wonder if it could be exhaust related. Does it sound like metal-on-metal? Does it do it all the time? (Start cold and continue even warm). How many miles does it have? Is it RPM motivated? Is the idle smooth? Is it constant or sporadic? Can you get it on a lift and remove the bottom shied to check from underneath?
On the accelerator (which is basically the throttle position sensor) try a reset:
1) Turn key to ON position (not ACC), but DO NOT start engine.... now wait a few seconds for the dash lights to clear
2) Slowly & steadily press accelerator pedal all the way to the floor and then slowly release at same rate.
NOTE: This step must be done ONE TIME only to ensure accelerator pedal position sensor calibration has been
learned by the ECM
3) Leave ignition switch ON for a minimum of 10 seconds. This will allow the PCM to learn the new electrical parameters
There is another method if that doesn't work:
1) Turn the key to the on position, the position just before the starter turns over.
2) Press the gas pedal firmly to the floor with the key in the "on" position.
3) Hold the pedal to the floor for five seconds, then turn the key back to the "off" position (don't remove the key), then release the gas pedal.
4) Wait 2 mins. for a full reset
Good luck
I have tried resetting the TPS that way but it seems to make no difference, no lightning bolt on the dash either
I don't know if there's a way to test the TPM, I would assume it's a glorified variable resistor but certainly could be more. It could be a dirty throttle body. Unfortunately, to replace the TPS is either $100 or $300 depending on version. The best troubleshooting step is to replace with known-good. If you get one and can return if it doesn't fix; I would.
Here's a link to diagnose: Chrysler 300: Bad Throttle Body → Symptoms + Diagnosis | Drivetrain Resource
None, can't seem to actually locate the origin of it. Sounds like engine
I listened to the video and all I could hear was 'awesome' but no rattle. How many miles are on it? I assume the oil level is full. Does the transmission behave properly? What kind of air filter is in it? (not starving for airflow)
Discussion Starter #12
Oil is full it has 250,000 k's trans behaves normal and it's running a pod with a larger surface area than the original filter
Mine is close at 148.000 but has a lifetime powertrain warranty. I have not found any info on the bearings (are they sleeve or roller) but it may be time to get the dealer to diagnose. At around $140 a reliable conclusion can actually save money.
Any progress on the idle lag?
Discussion Starter #14
Don't mind the smoke (a little oil on the exhaust manifold) but see if this video sounds clearer
Idle lag is gone (seems like it was an injector issue) idles nice now, seemed like the rattle was gone for about 5 mins of putting around some courts but it's still there now
Discussion Starter #17
Synthetic, but the rattle sounds metallic so I sincerely doubt it's a problem with the oil
Discussion Starter #19
Yea, this is actually what I have been thinking. The gen3 hemi is a roller bearing I believe, not looking forward to pulling the heads off if I am honest. Was hoping I could pinpoint it without doing so but I'm running out of ideas haha
1 - 20 of 21 Posts
