1 - 15 of 15 Posts
Gave Black Caviare a bit of squirt today and managed to crack the 1 G, left and right.
Still on the OEM rubber.
Whats possible with better rubber underneath.
Anyone already got better than this?
What kind of driving configs did you do to test? Circles in both directions?
The Industrial area is being extended with a piece of road that eventually loops back onto itself.
Looks a bit like a shortened race track at the moment.
I presume in time they will start putting buildings in the area, but at the moment it begs for it.
Discussion Starter · #6 ·
There are some scaving reviews over here on their handling but this shows they can hold their own pretty well.
By whom.... 'Motoring Journalist'? lol. Over an extended period I've learned that any vehicle bagged by the local motoring journalists should wear that as a badge of honour and I'd know I'm onto something good if they didn't like it.
My Chrysler handles pretty well, for what it is.
Discussion Starter · #9 ·
Going in for wheel alignment today. Wanted to do a before and after run.
Setting camber at -1.5 and reduce the toe in. Can't go as crazy as -3 like you have as it's mainly Street use.
I'd guess you have changed a few parts underneath as well to be able to pull that amount of Gee. Very impressive though.
BLOODY ADMENSTRUATOR
-1.5 and less toe in will make it feel like a sports car!
Only things different on my suspension are Pedder's bushings & sway bar & Eibach springs and adjustable shocks.
That's it.
Discussion Starter · #12 ·
I was testing on smaller tight corners and had the same type of problem.
Need to test out on the back roads on along sweeping corner like Patrick mentioned.
Reactions: germeezy3
Discussion Starter · #15 ·
I couldn't get past .99 either for a while
1 - 15 of 15 Posts
