I haven’t found a shop or person that’s willing to do it.. what are my other options if there’s anyIf you are dead set on doing this then you would need to research the pinouts and see if you can match them up. If you are trying to decide if it's possible, count the wires and see if at least they are the same, if so then it's likely possible.
I’m probably will keep the frame & just swap out the cushions.. I just gotta find an upholstery shop to do. Less of an headacheMight be a DIY project. I've done a few simple wiring connector swaps and although they are a bit time consuming, they aren't too hard if you are comfortable cuttiing and splicing wires. if not I'd suggest you keep looking for someone to do it. Maybe an decent Car Audio shop would take the project on?
