1 - 8 of 8 Posts
125hp shot on 5.7 hemi 386 RWHP
Has anyone done this before? I am running full magnaflow exhaust and high flow cats, an afeII and a predator. What type of horsepower at the wheels should i expect with a zex kit with a 125hp shot? Ok, just dyno'd 386 rwhp does that sound about right for that size shot cause before that i dyno'd 317 rwhp.
What times do you think i will run down the quarter using 275 40 17 drag radials.
BTW Anyone using a zex kit BE VARY CAREFUL WITH THE RESISTOR WIRE< AS MINE WAS BROKEN AND SHOT GAS WHILST THE THROTTLE BODY BLADE WAS CLOSED!!
i would be retarding the timing a bit with 125 shot fo sho. i never had the courage to run the 125 shot on my 5.7, but good luck and have fun
wow, ur gonna blow something up dude
what would you know your canadian
If you are using the predator I WOULD NOT use the high performance tune. Nitrous wants less timing..not more as the tunes in the predator will give you.
Ok, the reason i believe i wont blow anything up is that pre nitrous i was on the dyno monitoring the 93 cai tune, and i was able to tune the vehicle with the predator. We had to remove 5% fuel all round, then i added timing to the effect of 4, 3, 4. on those settings i did not get any knock and the car was awesome.
After adding the zex kit, i removed timing to the tune of 4 degrees retard so a total shift of 8 degrees all round. I also added fuel and left the fuel at 0 as opposed to leaning it out. The car showed a WOT AFR on the dyno of 10.8 which i believe was ultra safe, if some one disagrees please let me know.
BTW i am running 4306 v-power colder plugs and 100 octane fuel which is a blend of 5% ethanol.
1 - 8 of 8 Posts
