Right guys. Most of these dash cams have auto 'on' and auto recording.
Basically the way it is meant to work is that when you switch the engine on, power is sent to the dash cam via the lead plugged into the cigarette lighter and the dash cam switches on and starts recording.
Problem is, the 300 CRD has permanent feeds in the 12v cigarette lighter plugs weather the ignition is on or not..!!! This means the dash cam is either always on or you switch it on and off manually. Can this be changed in the car? Is there a way to stop the permanent feed in the plugs and change them to just when the engine or ignition is switched on? I keep forgetting to switch the camera on as the permanent feed means after my journey I have to switch it off manually..!!!!
