Keep an eye out for them @ krc performance. They made a post over on dodge talk showing some testing and tuning they have done.
"The base line back to back on the 2.7L Charger averaged 130 rear wheel and 124tq, thats right, 124. That is with 22" rims though.
If you caught the other thread, I installed a STS Turbo rear mount system, oil cooler assy and dynode with no programming and 2.5lbs boost at 165hp/ 185tq 12.1 AFR.
I changed the wastegate spring out and installed 28lb injectors. The car dynoed at 3.5lbs of boost, 11.7 AFR and 195rw with 230ft lbs. Blew the doors off a 3.5 HO Charger with it by 3 car lengths. At 5 psi, the car will hit 220rw and 260ft lbs. Here is a dyno run from todays work. This is an awesome way for you V-6 guys to make power yet keep the 28-30mpg figures. The HO v-6 can hit 300 rear wheel easily. We install the and tune the kit for $5499."
I wouldn't mind getting 300+ rwhp from my car! :smashfrea
