2005 300c mystery
409 Views 4 Replies 4 Participants Last post by  Smackeyacky
I have a 2005 SRT8 that was swapped wit a 5.7 Hemi how do I dine out the year of engine?? I took it to shop to get an oil change the guy said it’s not a 05 Hemi because the new filter didn’t fit!!! Then he said it mite be a 08 and up 5.7 Hemi but I just want to confirm it myself 🤷🏾‍♂️ HELLLLPPPPP ANYONE 🙏🏾
The engine number will tell you the year. If yours still has the sticker on the RHS head the engine number will be there. If the sticker is gone, the engine number is stamped on the skirt of the block on the LHS just above the sump but it's almost impossible to read without a camera of some kind.
There are other clues that involve removing the inlet manifold: once the manifold is off it's easy enough to discern the 2008+ "Eagle" motor by the shape of the ports in the cylinder head and the presence of the solenoid for the VVT cam phaser right at the front of the block.
See the last post on this thread for an example of how to decode the gen 3 hemi engine number:
Reactions: 3
If it has EGR it's def not an Eagle motor.
Reactions: 1
Or a 6.1.
Reactions: 1
It looks like to get the 2009+ eagle to work on my car, somebody kept the egr, put it on the blanked off mounting point, removed the pipes and plugged into the harness. I get no warnings about egr unless i unplug it. Car still has the 2006 PCM
