I don't know why you're asking about coolant again, but I'll recap.
If you check your owner's manual, you should find that the correct coolant for your car is Chrysler Pink HOAT. If you don't know what is in there now, you should perform a flush with distilled water to make sure that you get all of the old coolant out.
After a flush, it will be very difficult to get the correct ratio of coolant and water using premix. That's because your system will be filled with water, and unless you want to go through extraordinary measures such as blowing out your engine block and heater core with compressed air, there will always be a significant amount of water left in the system. So whatever coolant you choose, you'll need concentrate, not premix.
The part number for Chrysler Pink HOAT concentrate is 68048953AC. As it happens, I just bought some for less than $20 per gallon delivered to my door. Since it's 100% coolant, that's actually significantly cheaper than the Final Charge you found at Walmart, because that product is a premix, so you're really only getting a half-gallon of coolant for $12.56. So it's pretty clear that if you shop carefully, OEM coolant really isn't expensive at all.
But, if for some reason you don't want to use the OEM, Zerex G05 concentrate is a HOAT coolant and will do the job just fine. If you don't want to use either the OEM or Zerex G05, you can use Motorcraft Gold. If you don't want to use any of those, you can use whatever HOAT concentrate you want. But you shouldn't use Final Charge for two reasons, first, it is OAT, not HOAT, and not compatible with your car. Second, it is a premix, so again, if you do flush the system, it's going to be very difficult to wind up with the proper 50/50 mix if you start with a system partially full of water and refill with premix.
