As far as the flush I disconnected hoses and flushed throw top opening plugging bottom opening to build up pressure then let it go! I did that several times till water was clear! I then hooked everything up minus thermostat closed radiator pet cock then put one gallon coolant in reservoir and down too hose I put mix! Till it came out of engine where thermostat goes! Sealed it up topped up resivor and started engineWell car was blowing some steam from tail pipes! Not a lot! No watw in oil but the thermostat was out and after about 20 min it heats up to 235 ° it says that on the info center on dash! The gauge for some reason doesn't go past middle! And also after warms up coolant rises in radiator over fill! Fans do t come on and I tried to jump them but nothing! ( If I did that right)..? It doesn't miss I haven't tried driving it due to it gets hot! I used ttwo bottles of blue devil pour n go I put it directly in top radiator hose cold then started engine! It got hot within 20 min and had to turn it off! I started it back up at 170 ° and let it run but it got hot again in 10 min so I'm not sure if blue devil worked! I let it cool down then started it up and same thing got hot in 20 min! Light steam out of tail pipes still.. I'm stumped
