1 - 2 of 2 Posts
I have a 2005 Dodge Magnum R/T 5.7l Hemi AWD that I want to turn into a 300C Wagon.
I am pretty sure the nose of a 2005 300C will be a bolt on swap that will line up just fine with the doors of the Magnum, but I also want to change the Magnum wheels to 300 wheels (preferably keeping with 18" wheels so I can reuse my tires) but I'm concerned about which 18" Chrysler 300 rims will work on my AWD Magnum. Do they have to be rims from an AWD 300? What years interchange?
Thanks,
Away From 300C Forum
You are correct about the Magnum and 300 front fascia swap. Here is a really good How To on this swap:
How-to: 300 front end on your Magnum!
As far as the wheels you need AWD wheels, with that offset, to fit the front of your AWD Magnum. Here is a good source on wheel specs for the Magnum:
https://www.wheel-size.com/size/dodge/magnum/
Here is the same spec page for the 300:
https://www.wheel-size.com/size/chrysler/300/
You'll find the specs are the same for the first gen cars, whether it be a 300, Magnum or Charger.
1 - 2 of 2 Posts
