1 - 3 of 3 Posts
Hi All.
I`m a new member here. I working on a 2006 300c with the hemi 5.7 engine.
NON STARTER.
DONE SO FAR: new injectors, new fuel pumps , new spark plugs, new battery
key dance : no Codes
after ignition turned on CHECK ENGINE LIGHT flash 10 times ?????
after 3-4 attempt to start backfires at intake with lot of smoke.
TURNS OWER BUT A BIT SLOW EVEN WITH NEW BATTERY
HAD A SCANNER ON FAULTS:
- steering angle sensor not initialized
- B212D IGNITION RUN ONLY INPUT ( OPEN CIRCUIT ACTIVE )
- B2124 IGNITION RUN CONTROL 1
Any help and advice welcome.
Thanks for looking.
Positive they are B codes not P codes?
Initial reaction after seeing so much stuff replaced is crank sensor... Even possibly a cam position sensor.
1 - 3 of 3 Posts
