Attached is the 2006 Chrysler 300/300C/SRT8 Order Sheet & Code Guide - file contains a PDF document inside a ZIP file due to small filesize limitation on this forum for PDF format. Get Winzip at www.winzip.com to extract the PDF file.
7 pages total: The first 4 pages are the actual dealer build sheets (a.k.a. order sheets) and the last 3 pages are a matrix of the complete list of standard equipment among the various models of 300's from the base model all the way up to the SRT-8).
Some dealers don't have this yet or if they do its in the form of a nearly illegible FAX from the corporate DCX office, so for some people with 2006 300's/300C's/SRT-8's already on order it may assist you in knowing what exactly is going to be coming with your car. It may also show options that you weren't already aware were available to be ordered for the 2006 model year, and depending on your car's build status (safe to say your 2006 hasn't been built yet) you can safely modify your order and options without changing your place in line.
