1 - 8 of 8 Posts
My 300C overheated it was running fine then I shut it off now it will not start, it backfires and runs really rough but won"t stay running at all. I changed both the crank and cam sensor still no luck. Please Help
I'm sorry to say, you may have dropped a valve seat. I'd try a compression test.
I would second this. That is usually the case if you cannot run after an over heat on these engines. How hot was it, and what caused the overheat?
Discussion Starter · #5 ·
The Drivers side head had 2 freeze plugs get holes from corrosion that caused it.
1 - 8 of 8 Posts
