Sooooo story starts that the car was completely fine and not rising in temp like it is now. This started because the other day when it hit 108 degrees outside here in Texas and my car was running hotter than usual, the car hit around 230 degrees but the temp needle didn’t move from the halfway mark and the digital reading of the engine temp went down to the normal 220 degree range after a few stop n go traffic lights. So I tried burping it the old fashion way with the reservoir cap off and letting it run with the heat on when I got home, to see if maybe there was air in it as I’m an over thinker, after about 20-30 minutes the coolant started to spew out the reservoir so I quickly turned off the car then capped it after but the car was at normal temps the entire time I was letting it sit!! Woke up the next morning and poured more coolant in as a bunch came out as previously stated, turned my car on and did the burping process again and it still ran fine with no rising temps but I also didn’t put as much coolant in the reservoir so it didn't spew out again from it over filling, turned off the car and went back in for the day. Now this morning when I woke up I put coolant in it to the cold fill line and drove it, i barely made it out my big neighborhood and I saw the needle started to slowly climb up past the middle mark and the digital reading was 233 degrees so i quickly pulled over and inched it home after a few stop and go cool downs. I let it sit for a few hours then tried burping it again at an incline and I did see bubbles coming up but then the temp needle started to slowly climb up and the digital reading was reaching 230 degrees so I capped it because coolant was also overflowing as of course I was letting the bubbles come up out the reservoir… maybe I added too much coolant??? I only filled it slightly passed the cold fill line. Don’t know why it spews so much sometimes.
Some factoids:
- I’m not loosing coolant that’s noticeable except seeing some old coolant build up from where the top of the thermostat meets the water pump, which I just noticed as I haven’t been under the hood in a few months or so (a shame I know face palm … been busy with my other cars!)
- heater works just fine and blows hot like normal
- oil looks good and is clean
- coolant looks good and is clean, replaced coolant completely with ZEREX G05 about 8-9 months ago when I replaced the water pump!
- I noticed my fans kicked on immediately this last time I tried burping the car on an incline even though the engine temp was only at 125 degrees when I started it and the AC button was off and heat turned all the way up, is this normal????
Any ideas ANYONE? Please and thank you! Want to get this resolved! Could the smallest of leaks from the thermostat be why my car is now WANTING to overheat after a doing a random burping process? Why all of a sudden??? But then run normal but then overheat again when driving it? Bad tstat?
PICS BELOW ARE OF BUBBLES COMING OUT RESERVOIR THIS LAST BURP PROCESS AND THEN THE COOLANT BUILD UP ON TOP OF THERMOSTAT I FOUND.
Some factoids:
