Thank you very much and for sure.
But, just to get the full picture, let me tell you my story, so far.
I bought the car last December, you know, a dream came true!
Since I'm not and expert, I was able to check only the obvious things, looks good, no rust, leather inside looks good. All in all, it was a clean car, so I bought it.
Seller told me that in higher speed, there could be some "pulling" or "vibration", that is due to the bad engine mount rubbers, easy and cheap to replace.
This February, I went to a shop, just to double check the car.
The shop owner is a ... well .. you know, a really good specialist, but also, it has a really really bad attitude, let's just say he is really grumpy.
It turned out, the problem is not the engine support...had to replace a lot of things :
- all the breaks,
- full landing gear repair,
- all shock absorbers,
- cardan shaft,
- oil leakage fix,
Actually, the pulling comes from the transmission: wandler, as we call it in Hungary, erm, but you may know it as torque converter.
As you can tell, I've paid a lot for the above mentioned fixes, but, the car was finally in good mechanical condition, the transmission expert ordered the parts, everything looked really good.
After a week, the above mentioned problem came up...
So I've bought a new battery, because I've been told (judging by the symptoms and the cold winter here in Hungary) it needs a new battery, so be it.
It turned, it is not the battery, so I called the shop and the guy told me, it does not sounds like a mechanical problem, I should ask an electrician instead...
So...you see, I've got all the goodies, starting from a scammer seller all way to the not so supportive shop owner.
Now, a really good friend of mine give the number of his car mechanic, this guy is way more polite and most importantly, he is also really good.
I really hope he can fix this issue and after that, the transmission will be fixed and finally, the car is going to be in a way better internal shape.
