1 - 3 of 3 Posts
2007 300C SRT8
I love this car, but all of a sudden I cant open the driver side rear door from out side. Even if door is unlocked. The only way I can open it is to lock with fob and unlock quickly and pull on door handle at same time. How do I fix this problem. Now the other read door is doing the same thing. Pleases let me know if someone else has had this problem before.
Just curious, have you checked your child safety locks? Look for a little lock symbol on your door jambs. That shouldn't affect opening from outside, but you could try toggling them on and off.
Most likely you have bad latches and/or actuators, but it could be as simple as replacing the plastic bushings on the actuator arms.
2007 300C SRT8
Thanks I will check it out. Hope its not a pain in the Ass to take off and replace. I guess I will go to youtub and check out a video how to replace door handle.
1 - 3 of 3 Posts
