Hi,
My 2011 Chrysler 300 keeps having Overheating problems. I've replaced the Thermostat, Water pump, Temp Sensor, Radiator, Radiator fan a few times in the last year, and it still overheats. It doesn't overheat where the needle goes all the way to the red "H" Line, but it waddles back and forth. My mechanic has run test on the head gaskets, and he says they come back fine. It doesn't leak any coolant, I've changed the thermostat 3 times in the last 3 months and the temperature is ok for about a week or two, then the temperature needle beings to waddle back and forth. It only does this when the outside temperature is Above 90 degrees. Any Idea what might be causing this?
