1 - 1 of 1 Posts
In my case it turned out to be the water pump. I thought it was a loose exhaust header. The dealer is replacing the water pump and cylinder head at 50,100 miles. Fortunately, I bought the Max Care extended warranty for $1,508 when it had 23k on it. They are also replacing the delaminated U-connect screen under the same $200 deductible.
I don't know why the cylinder head & lifters are being replaced. The coolant usually ran 198 - 199 degrees. Anybody know why? Do you think it will be trouble again?
1 - 1 of 1 Posts
