1 - 3 of 3 Posts
hello all :i just put 22 inch dub moguls on my 2006 300c.i'm running perrelli scorpions 265 35 22 with a 9.5 inch rim on the front set. and same brand tire but different size on the rear im running 295 30 22 with a 10.5 inch rim. i just had them supposedly balanced but still shimmies at high speeds . is this just what happens when you go to tires this size ,u give up ride quality and handling or do i need them rebalanced .can anyone help thank you
Try rebalancing them first,,,,,
Could be one of many reasons:
Tie rods
Need Hub-Centric rings
Faulty Tire
Ball Joints or other suspension component
Clips holding the brake rotor on.. still on the car (Take them off with aftermarket wheels)
You shouldn't give up comfort with the larger tires/wheels. It is just a mismatch or balance issue somewhere, but try the re-balance first.
1 - 3 of 3 Posts
