After much research, I'm putting on 255/55/18 BFG GForce T/A KDW2's next week,toothdoc said:any body try 255/55/18 on the stock wheels any problems tread too wide? there are a lot more choices than 245/55. i am looking at nitto 420. is nitto a good brand, i have heard nothing on this brand good or bad?
If you live in a climate that goes well below freezing for several weeks, you need winter tires.FOAMAVEN said:Looks like a great tire, but what will you do for those cold winters up north? :wave:
I'm also looking for a wider replacement, but wanted an all season tire to avoiding two sets. Guess the BFG 245 may be the best bet for me.
Thanks for your help. I'll have to look into those. :notworthyNorthern Rider said:If you live in a climate that goes well below freezing for several weeks, you need winter tires.
I have Pirelli Scorpions for the winter. BFG make a an all season called KDWS which is quite good.
Thanks, I looked at those before i posted but he put them on custom rims I was unsure of new rim size he used. the 255 looked quite a bit wider than stock 225Northern Rider said:After much research, I'm putting on 255/55/18 BFG GForce T/A KDW2's next week,
Here are some threads:
http://www.300cforums.com/forums/showthread.php?t=90&highlight=255%2F55%2F18
http://www.300cforums.com/forums/showthread.php?t=7223&highlight=255%2F55%2F18
http://www.300cforums.com/forums/showthread.php?t=5879&highlight=255%2F55%2F18
http://www.300cforums.com/forums/showthread.php?t=5795&highlight=255%2F55%2F18
NR,
I'm also considering replacing the Conti's with the 255/55/18, and very much respect your opinion.
Just wondering if you included the Toyo Proxes in your research. I've never heard any mention (good or bad) of those as suitable replacements.
Thanks,
Russ
You are absolutely right. the 45 is a very close match.watchout said:Wouldn't the BFG 245/55/18's be a closer to original diameter than the 255/55/18's? I thought the original Conti's were 28.6. However, the specs on TireRack show 28, the BFG 245/55/18's are 28.5 and the 255/55/18 are 29.
I realize that's not a hugh difference, but wouldn't it be noticeable off-the-line?
Thanks much LWOODLWOOD said:Since I am not sold on the BFG's (although I hear they are pretty good) I really like Toyo Proxes tires, having owned several sets for multiple cars. Unfortunately, in 255/55 they are only in the S/T series which is a light truck style. It's pretty aggressive and one of forum members runs them. I PM'd him to see what his impressions are. I may go this route. As far as Toyo tores go, if they made a Proxes TPT in a sie we could use it would be no contest. They wear well, are pretty quiet have reasonable turn in and grip in corners and go like stink in the wet or light snow. I have had them on rear and front drive, stick and automatic cars. So, there's your unsolicited testimonial on Toyo Tires!
