hey guys/gals, just a quick question on what you guys are running (psi-wise) on your 265/35/22's. the guys at america's tire co. filled mine at 40 but that seemed a little high. t.i.a.!! :wave:
-brian-
The rule of thumb is add 1 lb of preasure for every inch you increase your tire diameter. When you open the drivers door it tells you the factory preasure. Then add 1lbs of preausre for each addtional inch. Example. I went from 18 to 22 inches, the factory calls for 30lbs, so my 22's have 34lbs. of preasure.
thanks guys... yeah, when i initially put the rims on the tire guys set it at 40 psi, that was 6 months ago, i just checked them a couple of days ago and they were at 34psi... guess i'll have to go and fill them.
-brian-
