1 - 3 of 3 Posts
Hello all, i have r22 9 inch rims on my 300c, all four tires was 265/35 as it should be, but i decided to put 295 tires on rear, good winter tires,
but its not too dangerous? 9 inch rim recommendations are 275 MAX, but i still tried 295 and it fitted nicely, but anyway, is there any dangers that i should be worried about?
Super Moderator
you may have to watch the fender that the tire doesn't rub. Potholes!!! can be a jarring ride. Better off to put a smaller wheel with some sidewall height for the winter and put them on when the better is better(depending on where you live ).
Your offset and the amount it shows in the rear wheel well is very similar to my 06 300C SRT8. I have 11 in. wide X 20 in. Foose wheels on mine and run 275/40 ZR 20's in the rear and 255/40 ZR 20's in the front. When I wear these out, I may consider going with a slightly larger rear tire, but I don't want it to stick out much more than it does now. No rubbing and the ride isn't all that bad.....at least not as bad as my Jeep GC SRT wanna be. It has a complete lowered SRT suspension, 9 in. X 20 in. wheels on front with 265/45 ZR 20's and the rears are 10 in. X 20 in. with 295/40 ZR 20's.
1 - 3 of 3 Posts
