So when I turn the AC off and I turn the dial all the way to cold it should just be something in outside air and blowing whatever temperature it is outside..
But for some reason it always blows slightly warmer. Is there some kind of heat leak from the engine?.
Is there a way to fix this?.
Make sure you have your recirculation button ‘off’. Otherwise, you wont pull in outside fresh air. (However, make sure it is ‘on’ when you go thru the car wash!)
the fact that it works fine until the engine warms up leads me to believe that there's just not enough insulation between the vent and the engine bay
