So I bought a used motor to replace my old 5.7 hemi long block which had a dead cylinder and caused it to fail compression checks. So after replacing the original motor I had my shop install the replacement motor and after 500 miles it started to make a ticking noise…..
In order to create a claim on the replacement motor I had to scope the pistons to check for debris which I did find a small piece in cylinder #1. I’ve been told it’s debris transfer as their are no valve marks on the pistons of that motor.
my question is:
Is it likely to get debris transferring back into the intake when my motor went bad?? My mechanic put the old intake back onto the motor this last round!
Welcome to the forum. Sorry your having ongoing motor issues. If your old motor dropped a valve seat, it's not uncommon for some of the debris to find its way back into the intake manifold. When a valve seat or valve seats drop, it is always recommended you install a new or known good manifold. It is also possible to insure the old one is good after a complete inspection and repair if/as needed.
That’s the generally what I’m hearing but my mechanics think it’s not possible….. looks like I’m gonna be tearing into the intake to look deeper into the problem, I’ll post what I find
So dug a little deeper into the intake and didn’t have to look far…. Took off the throttle body and shined a lite to the first drop in the intake and saw something that looked like tin foil.
Bore scoped the intake and just as I’ve been told their was a huge deposit of metals that looked like a diamond mine!!!
Debri transfer can and will happen with a catastrophic engine failure and I can’t deny it, proof is in the pudding!!
