So I somewhat screwed up and purchased a set of rear LED tail lights for my 300c that were actually for a 300. The ad on eBay was somewhat deceiving but seller won’t do anything about it as he did list that some modifications will need to be done for 300c . When I asked him what they were he said he doesn't know and go see a professional. Anyway here are some pics of the ones I ordered. Does anyone know what needs to be done so these will work in 300c. Oh they fit perfect just doesnt light up right.
actually i have a good idea since i was one who took part in the touring to c conversion for tailights. can i ask you what happends when you plug these into your car the blinkers and put a board under the rear tires and put the car in reverse so you can see the reverse lights tell me what happends, lastly this is tough you may need a friend hit the brake pedal and put on the blinker this is usually the big difference.... but either way i should be able to help you with this.
i bought a pair of regular 300 lights off some guy on craigslist for $20. i use them for when i get fix-it tickets for my tinted tails. they plug in and work perfectly with all the funtions working fine. im pretty sure those should fit your car fine
My car is going into the shop today to have tein coilovers put in so I wont have access to it all day. I will forsure try this out and get back to you as I really like these and want them to work. From what I recall the blinkers will work a few times then start flashing quickly once they start flashing quick the LED's stop working. The brake lights didnt work at all and I dont think the reverse lights worked at all either but I will hook them back up once I get my car back later tonight.
Thanks For the help with this
Kevin
