1 - 14 of 14 Posts
I've a 2007Chrysler 300c diesel have a ads fault code u140e can clear the fault but comes straight back on all wheel sensors are good check wiring everything seems ok can anyone point me in the right direction to get this sorted thanks
I've checked them and they are ok the fault came into the car after the battery was changed
Sounds like you might need a Starscan visit to a dealer to fix that then. Tim at the custom300cshop had that issue quite a few years ago: Link
These days it's a trip to your friendly Fiat dealer unless there's a local independent specialist (hopefully someone will know of one).
Per Fiat's website there's 3 in NI but no idea whether you're anywhere near them
Just scanned the thread from the beginning again. One question for you - how do you know the sensors are all OK?
Check rear fuse box for water. Also check link fuse from battery. This is the fuse for your problem. I had same issue.
Discussion Starter #14
I've checked the rear fuse box seems ok where is the link fuse is it at the battery
1 - 14 of 14 Posts
