1 - 20 of 77 Posts
Chrysler 300 Fog Light LED Bulbs
Diode Dynamics carries LED bulbs for replacement of your Chrysler 300 fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your 300's fog lights a nice bright white that closely matches factory-equipped HID lighting & LED DRLs! Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: Street Legal Output. Much brighter than factory. These are bright! USA Made!
Bulb Design
HP48:This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Chrysler 300).
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2005-2009 Chrysler 300
Diode Dynamics: Fog Light LEDs for 2010 Chrysler 300
Diode Dynamics: Fog Light LEDs for 2011-2014 Chrysler 300
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Our 1,420 lumen XML2 LED foglights are now available in 4300K and 5000K colors!
Give us a call if you have any questions! (314) 205-3033
Thanks,
Nick C.
I am interested in bulbs that will match my factory HIDs on my 300 SRT-8 as close as possible. Are those the 4300K bulbs you mention?
Can you send me a link to what I need to order to get what I'm looking for?
Our 4300K and 5000K options should be back in stock towards the end of this month. Your factory HID bulbs will be 4300K, so the 4300K XML2 LED will be a perfect match!
Nick C.
Nick C.
Ok thanks! I did see they were out of stock on your site. I will check back at the end of the month.
I just ordered some of these fog light bulbs and they got to my door in the UK faster than if I had got them from some place in England , great service , they are a great fit , and NO import duty ! Thanks PAT
Reactions: Diode Dynamics
I got the very bright ones , they look good and fit very well . I don't know how bright they will be and the car has just gone in the shop to have the engine pulled , so maybe some time till I let you know.
Just to ask I got no little in line box to cancel out my dash bulb failure lights ( can't think of the name ) as these LED's, are these built in ?
Shit you lot are quick !!! Wish all US parts places were like that ............................
Reactions: Jim777
What would I need to align the fog lights to look as similar as possible to the headlights on my 2013 300C with the HID light package? What brightness and color would I need? Also, what other parts would I need for them to function properly?
J
1 - 20 of 77 Posts
