Have had a very intermittent fault for a year or so now. When I drive away from our driveway the car occasionally stops accelerating and wont rev above 1500rpm. Basically I can limp along at about 10km hour. In the past this cleared after stopping by the roadside then taking off again with no further problem.
2 days ago I did the same pull over to the side of the road but the fault did not clear. Regardless of how far I pressed the accelerator, the engine revved at 1500 with a cyclic variation of about 100rpm every second. I disconnected and charged the battery for day and today it started and ran fine.
In all these cases the car was started after not being used for a couple of weeks and with some short runs when it was started so the engine turn over was quite slow (low battery).
I had thought there was a sensor fault of some sort but will a slower turn over with lower battery voltage potentially cause the ECU or other control module to get "mixed up"?
