300c won’t shift past first gear!
24K views 24 replies 10 participants last post by  Grumpy1
The speed sensor code is misleading. In fact, the problem is typical for Mercedes transmission
Unfortunately, being so simple to substitute, you will need to go a transmission expert that could charge about $200-$250 for labor
And once is damaged by usage, it will fail again in a year... it is called transmission 'limp status'
