I have changed the Crankshaft sensor three times and this morning going on the forth. When I do change it, it works for a couple of months then will crap out. This morning the 3rd went out on me. At this point I thinking it is not the CS sensor, but something causing it to died.
I have the code giving is the Crankshaft sensor and nothing else.
The first time it happen was at WOT, passing a truck on a on ramp, the car bogged down and started misfiring so I let up off the pedal and the CEL came on and the engine died. Second time was again at WOT, just having some fun with the V8, and same problem as above. The third was just pulling out my driveway and the car bogged down and CEL came on and the engine stalled. This morning, no bogging just engine shut off, no CEL, and restarted on first turn of the key, coming back home while doing about 40MPH the engine died, but turned itself back on, came to a stop sign and the engine stalled, for about 2 mins, I restart the engine and I soon as I put it into drive it would stall, hell I drove it home with two feet.
I am thinking either, PCM (hope not), throttle body, or pedal position sensor?
SGB
SGB
