You have to know someone who knows how to use an exclusive feature on this forum called search.eudaman said:who do you have to know to get some response on wheel weight? geeeeez!
ok searchmaster, i bow before your most excellent searching prowess! i did look though....the missing link was the toyo tire weight. somehow neglected venturing to the toyo site.frank29 said:You have to know someone who knows how to use an exclusive feature on this forum called search.
Stock wheel weight is listed at either 24 lbs or 26 lbs in various threads, an example is: http://www.300cforums.com/forums/showthread.php?t=1140&page=3&pp=10&highlight=weight+stock see post #25.
As far as a Toyo tire, go to toyo.com, navigate to your particular tire, click on "get the tech specs" and you will get a lot of info including weight.
Geeeez!
eudaman, you might be asking for trouble. I have no interest in changing my stock wheels, sooo, I haven't paid a tremendous amount of attention to the threads addressing this. That being said, I have picked up: that amount of extra weight (about 40% increase) is going to cause a whole host of problems (handling, safety, braking, and God knows what else). I wouldn't do it. Apparently, the safe way to do it is with a more expensive forged wheel.....the cast wheels may look just as good, BUT.eudaman said:should i nab a 22 lbs overweight setup? performance issues....?
I did some looking around for this answer because I may eventually store my stockers, if I get 20 inchers.joshmillslane said:I just installed my MC2ning FZ6 wheels. 20" with Toyo Proxes.
I stuck one on the bathroom scale before putting it on...about 55 pounds. Damn heavy.Not sure what the stockers weighed in at with the self sealing Contis. I put em in storage before I could weigh em. On that note, what's the best way to store a wheel and tire long term? On the side or on the tread?
Josh
Josh,joshmillslane said:I just installed my MC2ning FZ6 wheels. 20" with Toyo Proxes.
Josh
