Good thought, yes, the air switches properly. I felt the lines while it was running, doesn't seem to be getting cold. Best case, small leak. Worst case, compressor.I suspect your HVAC blend door may be stuck. When you switch from vent to defrost to floor does the air come out the proper vents?
Have your system leak tested and recharged.
No, the comp. stays on continuously.Is it fast cycling?
Ya, there tight. I would think if something was not connected, i wouldn't get lights and fan function. It will heat up when I turn it to heat, and switch vents and all. I'll check again to make sure I didn't miss anything.In that case I would check and make sure you snapped all the plugs in tight.
There is a TSB for the 2005 model year 300s:Feel free to review the link below. I have had similar issues where the Air works 10% of the time extremely well. I know it is not the compressor.
http://www.300cforums.com/forums/ge...uble-shooting/162354-heater-c-issue-help.html
Am planning on bring it to the Dealer but just have not had time / need YET. Still reasonably cool in Toronto.
Intersted to see what you find.
TSB 24-004-05
SUBJECT:
Flash: Poor Or Intermittent A/C Performance
OVERVIEW:
This bulletin involves verifying the proper A/C system charge and selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software.
MODELS:
2005 (LX) 300/Magnum
SYMPTOM/CONDITION:
The vehicle operator may experience on of the following:
· A/C cut-out
· A/C cut-out at low speeds
· **A/C cut-out at highway speeds 5.7L engine**
· Poor A/C performance
