It's in the front integrated power module (fuse box) under the hood on the left side.
Does anyone knows where is the a/c / relay is on a o6 Chrysler 300c 5.7
thanks Maddog this is big. But do you know how to test it. #4 fues keep blowingIt's in the front integrated power module (fuse box) under the hood on the left side.
Thanks maddog. So the relay is good and the fues good but there are no power at the plug, but where I jump at the relay there are power at the plug, what does that mean? And do the ac line have to have freon in it to activate The power.Blowing a fuse means you have a short in the wiring or a failing A/C compressor clutch.
Yes the AC is not going to engage the clutch if there is no freon need to evaluate the system and refill.Thanks maddog. So the relay is good and the fues good but there are no power at the plug, but where I jump at the relay there are power at the plug, what does that mean? And do the ac line have to have freon in it to activate The power.
