Originally posted by 99gt
lol... how do people figure they get a 10-15 RWHP inccrease out of a naturally aspirated car with CAI
I'll answer this one: A basic understanding of physics is required
In general Cold air intakes increase RWHP (on a V8 engine) because they bring in lower temperature air, which is not from under the hot hood area. The thing about lower temp air is that it is
higher density than the hot air under the hood. It therefore contains
more oxygen for combustion for a given air volume. It therefore require a bit
more fuel to keep the mixture correct, this gives the RWHP increase - so far so good.
On fuel injected engines with a MASS AIRFLOW SENSOR (MAF) Def: A device used to measure the amount of air entering the engine so the computer can control the air/fuel mixture. The computer adds a bit more fuel to the higher density air to keep the mixture correct and adds a bit mor RWHP
Unfortunately Chrysler opted for a SPEED DENSITY injection system which has a fixed injection profile in the computer for that engine's fuel requirements. It cannot self-adjust the amount of fuel for extra airflow from a well designed CAI. So no RWHP gains will be seen, or dynoed.
Only a hack into the injection computer software, or a black box, will allow changes in the fuel for cold air. The SPEED DENSITY method of monitoring air intake is a stumbling block to installing high-performance engine components Chrysler is not releasing the software code to make a hacked adjustment or black box easier.
With SPEED DENSITY injection there are limited situations where extra airflow can be beneficial to RWHP but the require other mods and can never be really accurately calibrated due to the fixed profile factory SPEED DENSITY inj. software
BEWARE of any advertising that currently says CAI increases RWHP on the HEMI.
Not too much Blah Blah Blah I hope, but you deserve a full explanation
