1 - 8 of 8 Posts
I'm new to the scene and I have a problem.
The ABS and ESC brake warning lights are on. I coded the car {2005 chrysler 300} it said right rear , I then replaced the sensor and it didnt clear the lights.
I talked to a chrysler mechanic and he said it is probably the half shaft or cv axle.
I have had no luck in finding one as nobody has them in stock but can have one rebuilt by sending it to philly.Chrysler says they only made them for that year and there is not any call to replenish them.
Any help would be appreciated.
You say you replaced the sensor? Did you clear the code after that?
I'd try clearing the code.
Best way to do that is to find your AutoShutOff/PCM fuse in the underhood power center (check your owners manual) and pull it for 60 seconds. Replace it and fire up the car. If it doesn't clear, read the code again and we can go from there.
Hi and welcome!
Welcome from Michigan! :D Get-er squared away?
1 - 8 of 8 Posts
