Nope, you'll be fine :wink1:kobe8 said:I accendintly pushed the 87 ocatne(Regular) on the pump instead of 89. I had put less then 3 gallons in when I realized that I pished the wrong grade. Will this damage the engine any.
YES!!!! Get the hose and start sucking!kobe8 said:I accendintly pushed the 87 ocatne(Regular) on the pump instead of 89. I had put less then 3 gallons in when I realized that I pished the wrong grade. Will this damage the engine any.
...heh...heh :biggrin:jjs said:YES!!!! Get the hose and start sucking!
:wave:
:wave:
HEMEEE said:jj, did you have a bad weekend baby, or are you just bored and mischievous? :slap:
well........I hate to be the bearer of bad news, but you need to go to the service department IMMEDIATELY. You need to have a new engine installed and you'll probably have to replace your transmission as well. Unfortunately, you probably need new seats (fronts only) and a new headliner. It's quite possible that you'll need to replace your rear deck speakers and install the rearseat DVD player to reverse the effects of the gas you used.........kobe8 said:I accendintly pushed the 87 ocatne(Regular) on the pump instead of 89. I had put less then 3 gallons in when I realized that I pished the wrong grade. Will this damage the engine any.
Well, I'm glad you didn't get beat up by Rita!jjs said:bored and mischievous
long 'butt' weekend of moving crap for Rita, moving it back since nothing much happened near me, running to and from the frickin' office for network backup and reboot. Sooooo, since I am stuck here at the office again, thought I might have a little sarcastic fun!! :wink1:
