1 - 3 of 3 Posts
I know there are alot of questions about what harness to use for which 300 and blah blah blah.....I have written 2 or 3 myself.
Anyways, I have an 05 Limited with factory amp.
I am starting with an Alpine double din screen, swapping out door and rear deck 6x9's with Infinity Kappas, and a 12" Kicker L7, with Kenwood amps.
Simple question, since I'm running my own amps, can I just splice into my factory harness for the 12V, ACC, and GRND??? That way I can bypass buying the expensive harness since I won't be worrying about the factory amp. I'll be using the RCA outputs on the Head Unit for amp power.
Hopefully it's a simple question that requires a simple answer...hahaha.
Thanks!!!
you could, but there is no ACC wire.
You have to get that from somewhere else. Others have done this.
I have read you can just get the ACC from the cigerette lighter.
Does anyone have a diagram, or know which pin on the Factory harness is 12V and Ground???
Thanks
1 - 3 of 3 Posts
