I am kinda wondering the same thing, as i am thinking about retrofitting the mygig in my truck.......i know a lil bit about electronics.....i like the mygig, cause it has a HDD to store stuff on it.......so hopefully i will be able to find out!!!What would you do?
If you had a choice between buying an aftermarket unit, or buying a Used OEM unit from a forum member or Ebay. The cost is roughly the same.
I was going to go with a Z3 all the way, but then I got used to the station being displayed on the evic, hence my other post.aftermarket all the way. you get way more than navi w/ a aftermarket unit!!
http://www.300cforums.com/forums/ca...tion/58042-evic-display-aftermarket-navi.html
If it shows anything like "FM 00" or anything else besides the station, it's going to annoy the hell out of me. I know I can change the entire display to show something different, but if I want to use the stearing wheel controls, it has to be put back to the default screen.
Once I man up and figure out what I am going to do, I'll ask the wife if its ok.![]()
not sure if the my gig will work on your truck, it wont give sound to us with lx's from 05-07I am kinda wondering the same thing, as i am thinking about retrofitting the mygig in my truck.......i know a lil bit about electronics.....i like the mygig, cause it has a HDD to store stuff on it.......so hopefully i will be able to find out!!!
yeah i can almost gurantee my gig will not work on your truck it works on very few cars retrofitted. if you are trying to go retrofit just avoid and go aftermarket you will probably end up with more functionality.I am kinda wondering the same thing, as i am thinking about retrofitting the mygig in my truck.......i know a lil bit about electronics.....i like the mygig, cause it has a HDD to store stuff on it.......so hopefully i will be able to find out!!!
