i'm going to be installing an Alpine DVA-9861 headunit and was wondering if there is an install harness i need and do i need an antena adapter to fit the magnum antena into the Alpine unit.
also, i'm going to need an inverter to run my monitor and playstation, does anyone have any ideas what size/wattage i would need.
thanks
yes you need a metra harness and a antenna adapter. i dont know about the inverter. i have one in my truck(semi) it's a 400w i use it to power my tv/dvd player, im assuming that should be fine for a ps.
thanks guys.
i don't have a factory amp or steering controls so would that be the harness you listed still?
i'm running ps3 and a 24" monitor. the ps says it runs off 150w and the monitor says 280w. i'm assuming i will need something with 500w or more to run them both at the same time, is this correct?
