1 - 3 of 3 Posts
I have a 2018 300 limited with the Alpine system. I have heard that you can swap the amplifier from the 276 watt Alpine amp to the 550 watt Beats amp or the 900 watt HK amp. Is that possible and is it plug and play and what will be the sound difference.
There are treads on here about this. If I remember correctly, you cannot swap the HK amp since the wiring harness is different. I think it said the Beats amp is a direct swap. here is a tread I found you might find useful.
Forgot to add the link:
1 - 3 of 3 Posts
