I also saw this head unit on Seicane. How did this go for you?Hi,
I'm going to buy an Android radio and I wonder if the serial "Kicker" subwoofer will work?
Radio from AliExpress
Teyes CC3 supports my "Kicker" subwoofer. Everything works fine.I also saw this head unit on Seicane. How did this go for you?
Was it as simple as plug and play? Did you have to bypass factory amp for sound? Steering wheel controls and all?Teyes CC3 supports my "Kicker" subwoofer. Everything works fine.
Yes, P&P. The radio comes with a Can-Bus adapter. You can control from the steering wheel.Was it as simple as plug and play? Did you have to bypass factory amp for sound? Steering wheel controls and all?
As simple as plug and play gets. I hooked everything up and gave it power to test and everything just worked.Did your steering wheel controls work right off the bat, or did you have to program them in?
That’s cool I have one from Elemento tuning and there not workingAs simple as plug and play gets. I hooked everything up and gave it power to test and everything just worked.
Did it come with a canbus decoder?That’s cool I have one from Elemento tuning and there not working
Also there's a little white plug that comes out of the harness adapter that goes back into the head unit, that may be easy to miss.Did it come with a canbus decoder?
