The sub box is just a box, it contains a 10"sub. The amp is located separately. Do some searches and look around LX forums as well, i know some magsrt8 people have relocated their sub or at least were talking about doing it. Bottom line, your Kicker sub will be awesome in your mag as is. In an open cabin, that sub is even stronger.RobertV said:Once I get my M SRT8, I plan to build a box for the sub that fits in one of the side storage areas in the rear.
What is inside the sub box?
Is there an amp in there?
What is the size of the speaker?
TIA
KCUSTOM you are the the wise one. My info was incorrect. Next time I will send out the bat signal when kicker questions arise......................KCustom said:The amp is seperate in the 300 and Charger, but in the Magnum the amp is mounted inside the woofer box...If you will replace the M12 nut with an M12 wing nut you will find out that the assembly install and removes in less than 30 seconds.....
