I have a new 300C. When I use autostick it only shows gears 1 through 4. Does that mean that I have a four speed transmission? I was under the impression that the 300C came standard with a 5 speed transmission.
Thanks.
BLOODY ADMENSTRUATOR
Thanks.
It is a 5 speed. The autostick just gives you a more agressive option for the first 4 gears. Enjoy!
Autostick
Thanks.
When you shift up the ladder you have noticed that indicator goes 1-4 then on to "D". "D" = 5 th in autostick mode.
Thanks.
when you hold it in "4" and then shift up to "D" it should go into 5th gear, assuming you are going fast enough; you can feel it shift or watch the RPM's drop on the tach. There is no way ( on a 'regular' C) to hold 5th gear manually, as there is on the SRT8. But it definitely is a 5 speed automatic.
Well that's "kinda" true; "D" actually is the fully automatic mode, which will allow the transmission to shift into 5th gear at the appropriate speed. There is no way to hold 5th Manually in the C, but you can in the SRT8; it actually shows "5" and THEN the next step is "D".
Same transmission, just different software and autostick functions; they are both 5 speed automatics for sure.
