1 - 3 of 3 Posts
OK, I've done this twice now. When my car is in 2WD (front axle disconnect) and I put it in sport mode (turn igntion key as to start and hold for 5 seconds until chime sounds and BAS and ESP lights come on) it displays "check AWD system" message and stays in 2WD regardless if I manual shift or if the back tires slip. Has anyone else with a 2009 + LX AWD tried this? Once I turn off and restart all is back to normal.
Discussion Starter · #2 ·
Laid rubber in my AWD. I finally let of the gas to preserve rubber. When you are in AWD and put it in sport mode, it stays in AWD. When you are in 2wd and put it in sport mode, it gives you the "check AWD system" light but stays in 2wd even if you use the auto stick or the back tires spin. Has anyone else with a 2009+ AWD tried this?
this sounds cool
1 - 3 of 3 Posts
