catchMEifUcan took apart his navigation unit and found the RGB and sync lines leading to the monitor itself. They do exist, but there has been no documented evidence that any of the modded units people own are using them. I believe most units are using the AVelectronic mod.joe300c said:Probably because they're disabled, so it'll take a hacker to figure out if there's a software method or solder method if any method at all to enable them. The deal is ofcourse that this is off the shelf Alpine componentry that DCX is OEM'ing so it was cheaper to get this alpine box and trim it down to DCX's requirements rather than reinvent the wheel. ofcourse in the trimming process they disabled the inputs in the o/s.
Anyway it would APPEAR that the people at the avelectronic dot com link have figured out how to enable that AV input on the 300C's nav unit.. sucks having to run a SEPARATE dvd player though to get video to it.
sure can........puff puff puff...:-()o o0 0 ojoe300c said:Can one of you guys explain what CANBUS is?
