Ah, battery threads, goody goody.
We are quite lucky with our cars, in that the battery compartment is actually a decent size. So can fit the correct battery. We don't have to play that stupid game where we have a torch battery squeezed under the bonnet that is the size of a cigarette packet, but is "latest tech/trust us!!!" Truck and 4x4 batteries typically keep the correct acid/casing/plate ratio, that is, "twice the CCA = twice as big physically". Under bonnet batteries don't, and make ridiculous claims. ALL the "wonder CCA's in small packages" I replace last 3 years. Every battery in MY cars are correct ratio (realistic) hence I get 7/8 years out of a battery.
My 2007 V6 had the original factory battery (730/72 A/H when I bought the car. It never let me down, but one day did the dreaded "Ur - RUR" , then started the car, so I replaced it. 2007 car, 2016. So orig was almost 9 years old. That car is still here, that replacement battery is now 7 years old, still ok.
My recently bought 2006 V8 has just had a new battery. Battery in the car started it ok, was a "bit small" for the car, (or for my liking) at 70 A/H, and 640 CCA. It starts the car fine, and load tests perfectly, but is a 2108 battery, so 5 years old. If it were 80 A/H, I would leave it 2 years, but I prefer the full spec, so easier to replace.
Century here recommend a 730 CCA/80 A/H. That is shorter than the holder. I bought a 810CCA, 90 A/H. It is the longest battery that will fit. There is one that is that length and physically HIGHER, and it fits (and has proportional CCA and A/H increase), but that puts terminals hard against boot floor, and I don't like that.
So, basically, our batteries are large and generally observe the rules of physics and have realistic CCA claims versus package size. Because of that "proper ratio" (and also, in boot, run cooler) they usually last a while. As above, my first one 8 years, second one 7 years (still ok) , one in V8 5 years (still ok).
Yours at 7 = probably get another year out of it............................... but is that day you get stranded worth it?
So, you can do 3 things.
1. Ignore and wait. Probably in a year, in might let you down.
2. Buy a load tester for 15 bucks. Regularly load test it, (after fully charging it) and when it drops below about 700 CCA = buy a new one.
3. Accept that 7 years is a good run = buy a new one, have no worries. Get the largest package that will fit, and around 80/90 amp/hours, and approx 750/850 CCA.
BEWARE of "miracle new tech................. gazillion CCA!!!!!" batteries.
I am wary of "new battery tech" as have seen so many come and go. In the mid 80's, the Exide "Torque starter" gel battery was going to "change the automotive world". I had some gel batteries EXPLODE on a boat. They don't handle surges. I was labelled "old fashioned". How DARE electrical techs (who have had a few explode) challenge marketing?
They exploded in cars. They VANISHED from the market, almost bankrupted Exide. They quietly went back to "normal" LA batteries.
Honestly, at the time, our Oberon subs had 448 lead acid battery cells. 224 tons of batteries worth millions. If gel were THAT good, we would have been using them??????
I hope that is of use/interest and helps you decide. If it were me, at that age, I would replace it with a realistic spec battery. As I said, the "snake oil miracles" are usually for the smaller "under bonnet" batteries, ours seem immune so far, but just for info. If something sounds too good to be true, it usually is, and 800cca - 80 A/H in that large package are perfect for our cars.
