Hello,
I just picked up a 2006 Chrysler 300C with the 5.7L Hemi for a steal, knowing that it had an unidentified "misfire" problem. Now that I have it home, the car seems to be able to run, and is mechanically excellent.
The first time you start up after a full night "cold soak", the car will run for maybe 10-20 seconds, before bogging down and shutting off. The ESP, ABS, Mr. Squiggles and CEL are all on immediately.
The second time you start it up, the car can idle almost forever, and is very smooth and quiet. If you attempt to drive, however, the car is stuck in limp home mode. (This is accompanied by the P0501 code.) Eventually, the car will bog down and stall at idle.
Every start attempt past this point will just bog down almost immediately and stall. Once the car reaches temperature, codes P1128 and P1129 appear.
Consistently:
P0031
P0037
P0051
P0057
Intermittently:
P1128
P1129
P0501
P0300
U0100
Any ideas as to what this could be? My car is obviously undrivable in this state, and very unsafe. Please, any help is so greatly appreciated.
Consistently:
P0031
P0037
P0051
P0057
Intermittently:
P1128
P1129
P0501
P0300
U0100
