Here's a little more on TSB 22-004-03:
Chrome wheels should be cleaned regularly with mild soap and water to maintain their luster
and prevent corrosion. Wash them with the same soap solution as the body of the vehicle.
Care must be taken in the selection of tire and wheel cleaning chemicals and equipment
to prevent damage to wheels. Mopar Wheel Treatment, p/n 05066247AB – 12 oz. or
05066248AB – 5 gal., is recommended to remove normal brake dust, dirt, grease and grime.
NOTE: To clean extremely dirty wheels, Mopar Chrome Cleaner, p/n
04318013, is recommended.
Any of the “DO NOT USE” items listed below can damage or stain wheels and wheel trim.
DO NOT USE:
• **Wheel cleaners that contain hydroflouric acid, biflouride compounds, sulfuric acid, or
phosphoric acid.**
• Any abrasive type cleaner
• Any abrasive cleaning pad (such as steel wool) or abrasive brush
• Any oven cleaner.
• A car wash that has carbide tipped wheel-cleaning brushes.
CAUTION: Many commercial wheel cleaners contain acids that may harm the
wheel surface. **Avoid all “wheel acid” type cleaners.**
CAUTION: **Any facility found using acid based wheel cleaners will void all wheel
warranties, and all damage to customer wheels will be the facility’s responsibility.**
